I'm supposed to install an update from my service provider. But there's a meesage that says it can't because of a program and I am to uninstall and then I can proceed. The program I am to remove is H+BEDV AntiVir Personal Edition. I deleted all Anti Vir programs I could find. The search does not turn up anything with H+BEDV in it. What is that and where can I find it to uninstall/delete it?
H+BEDV removal....
Tags: None
I think that's possibly related to Avira:
Avira AntiVir Personal - Free Antivirus
Which is probably better than whatever they're telling you to install instead.Tr
y -
what you can do, and be very careful about it, is to type in REGEDIT in the start or run window. When REGEDIT shows up is go to EDIT and type in the filename or part of the file name in the box and hit FIND. Every instance that the file shows up in, right click the item and DELETE it. Then hit F3 or FIND NEXT. Do this for every instance regedit finds the file. What you are doing is removing the "mirror-file" found in the registry. Just be very careful because this is the thing that windows runs under.Comment
Signal barely reaches my detached garage where I do most of my projects, and it's basically useless out there for looking up parts diagrams or streaming...
Channel: Computer Repair
