verrifying DMI pool data message
  • walshdad5
    About 2 weeeks ago,we turned on our computer and it came to a dark screen with the message,"verrifying DMI pool data".I turned it off,and tried again,but got the same message.If after turning it on,I hit f12 and go through the boot menu,it works and goes to windows.We have been leaving the computer on and it seems to be running o.k.If I turn it on it goes back to that same message,any ideas?Thanks!
  • Glotharg
    • May 2009
    • 24
    Looks like an issue with your BIOS settings.
    Make sure your bois is set to Auto when finding hard drives
    You may have to turn off and unplug your computer. Pull the power plugs out of your hard drives and turn it on... then turn it off.. unplug it, plug in your drives again, and start it up. Make sure you touch the metal frame of your computer before you unplug it.. don't want to give your system a static shock.
