CRITICAL_PROCESS_DIED' blue screen error on Dell XPS 15 laptop
  • Annahmed
    • 223
    Hi everyone!
    Can someone explain and help fix this issue:
    'CRITICAL_PROCESS_DIED' blue screen error on Dell XPS 15 laptop
    Thank you!
  • machinist
    Moderator
    • 386
    Hi there!
    Have you recently installed any new software, drivers, or Windows updates that might have triggered the issue? Sometimes a new update or driver can conflict with your system and cause crashes. Also, are there any signs of hardware problems, like overheating, unusual battery behavior, or strange noises from your hard drive or SSD? If so, that could indicate a hardware-related cause.
    It might be helpful to check the Windows Event Viewer for any error logs around the time the crash happens, as it can provide more specific clues about which process or service is failing. Have you run any diagnostics on your hard drive or SSD recently to check for corruption or wear, like using the "chkdsk" command? Additionally, does the error persist if you boot the laptop into Safe Mode? If it works fine in Safe Mode, the problem could be tied to a third-party application or driver. Finally, have you had a chance to run a memory diagnostic test to rule out any issues with your RAM? Faulty memory can sometimes lead to these kinds of errors as well.
    Answering these questions might help uncover what's causing the problem and get you closer to a solution.​
    • Annahmed
      • 223
      Hi machinist!
      Windows 11 recently updated. Drivers updated, chkdsk and memory diagnostic checked. Event Viewer showing no clear culprit. Is this likely a hardware issue, and which component should be checked first?
      • machinist
        Moderator
        • 386
        Not sure, here are a few things to check.
        Software Issues
        1. Corrupted System Files: Even after updates, system files can become corrupted. Use the **System File Checker (SFC)** and **DISM** tools to scan and repair these files. Open Command Prompt as an administrator and run:
        - sfc /scannow
        - DISM /Online /Cleanup-Image /RestoreHealth
        2. Driver Conflicts: Conflicts might arise even with updated drivers. Consider rolling back to previous versions of critical drivers, especially graphics or network drivers, or perform a clean installation of the latest drivers directly from the manufacturer’s site.
        3. Background Applications: Third-party applications may interfere with system stability. Performing a clean boot can help identify if any startup programs or services are causing conflicts. This loads only essential services and can reveal problematic software.
        4. Windows Settings: Sometimes, specific Windows settings can cause issues after an update. Check for any known bugs associated with the latest update and consider temporarily reverting to a previous version if necessary.
        Hardware Issues
        1. Hard Drive/SSD: Even after running chkdsk, deeper issues may still exist. Use manufacturer-specific diagnostic tools (like CrystalDiskInfo) to check the health of your storage device, looking for signs of failure.
        2. RAM: If the memory diagnostic didn’t reveal problems, try reseating the RAM sticks or testing them individually. A more thorough test using **MemTest86** can help detect subtle memory issues.
        3. Overheating: Monitor the CPU and GPU temperatures. Overheating can cause instability. Ensure that cooling systems are clean and functioning properly, and consider reapplying thermal paste if necessary.
        4. Power Supply and Motherboard: If hardware checks don’t show any issues, inspect the power supply for consistent voltage output. A failing PSU can cause random crashes. Additionally, check the motherboard for any physical damage or loose connections, as these can lead to system instability.
        Examining both software and hardware angles can narrow down the potential causes of the issue. If troubleshooting doesn’t resolve the problem, consulting a professional for deeper diagnostics may be the next best step.​
        • Annahmed
          • 223
          Thank you for the detail answer, machinist!
