Laptop cleaning
  • Gardenboy
    • 334
    Laptop cleaning
    Hi everyone!
    I’m wondering how often I should clean my laptop to keep it running smoothly. Also, what’s the best way to do it without risking any damage?
  • machinist
    Moderator
    • 386
    Hey there!
    Ideally, you should give it a light cleaning every couple of weeks and a deeper clean every few months.
    For regular cleaning:
    • Keyboard & Exterior: Use a microfiber cloth to wipe away dust and fingerprints. If there’s stubborn dirt, you can slightly dampen the cloth with water or a mix of water and a little mild dish soap (just make sure it's not too wet).
    • Screen: A microfiber cloth works best. If needed, lightly dampen it with distilled water or a screen-safe cleaning solution. Avoid spraying directly on the screen, spray onto the cloth first.
    • Vents & Ports: A can of compressed air is great for blowing out dust from vents and ports. Just be sure to hold the can upright and use short bursts to avoid moisture buildup.
    For a deep clean every few months, you can carefully open the back panel (if you’re comfortable doing so) and remove dust buildup from the fans with compressed air. This helps prevent overheating.
    Hope this helps!
    • Gardenboy
      • 334
      Thanks, Machinist! I’m also curious, could dust buildup on the fan be causing extra noise, or is that usually a sign of something else?
      • machinist
        Moderator
        • 386
        You're very welcome! Yes, dust buildup on the fan can definitely cause extra noise. When dust accumulates, it can make the fan work harder to cool the system, leading to louder operation. It can also cause uneven airflow, which might make the fan wobble or produce a rattling sound.
        However, excessive noise could also be due to other factors, like a fan bearing wearing out, high CPU or GPU usage making the fan run at full speed, or even something physically obstructing the fan blades. If cleaning out the dust doesn’t reduce the noise, you might want to check your laptop’s task manager (or activity monitor on a Mac) to see if a background process is putting extra strain on the system.
        • Gardenboy
          • 334
          That’s really helpful, thanks! I’ve seen some laptops with anti-dust self-cleaning fans, do those actually make a big difference in keeping dust out, or is buildup still an issue over time?
          • machinist
            Moderator
            • 386
            You're welcome! Laptops with anti-dust self-cleaning fans can help reduce dust buildup, but they don’t completely eliminate the issue. These fans typically have a design that directs dust particles out through special channels instead of letting them settle on the blades and heatsinks. This can improve long-term cooling efficiency and reduce the need for frequent deep cleaning.
            However, over time, some dust will still accumulate, especially in areas around the vents and inside the laptop. If you use your laptop in a dusty environment or on soft surfaces (like beds or carpets), buildup can happen faster. So while these self-cleaning fans help, it’s still a good idea to do occasional maintenance using compressed air to clear out vents and keeping the laptop on a hard, clean surface to minimize dust intake.
            • FatimaandAhmed
              • 343
              I have an ASUS TUF with self-cleaning fan technology, and it does a pretty decent job of minimizing dust buildup. But Machinist is right, dust still accumulates on the fans over time. I still need to clean them every now and then to keep things running smoothly.
              • Gardenboy
                • 334
                How do you usually clean the fans? Are soft brushes safe to use on them, or is there a better method?
                • FatimaandAhmed
                  • 343
                  I use a makeup brush, it’s super soft and works perfectly for dusting off the fan without scratching it. Honestly, it feels like I’m just giving it a quick touch-up, like a little beauty routine for my fan!
                  • machinist
                    Moderator
                    • 386
                    A makeup brush is a creative and gentle way to dust off your fan, and it’s great for quick touch-ups! For a more thorough clean, though, you might want to go a step further. Using compressed air is one of the best ways to remove built-up dust from laptop fans and vents. Just be sure to hold the can upright and use short bursts to avoid moisture buildup. If the fan is still clogged, carefully opening the laptop (if possible) and cleaning with a small anti-static brush or a soft microfiber cloth can help.
                    • Gardenboy
                      • 334
                      Thanks, everyone! Super helpful stuff!
