Hi all,
New homeowner here, just bought my first house, and now I've got my first real problem that I need to ask for help on.
We've had a pretty abnormal April so far, with several inches of snow and rain. The rain is falling while the snow is melting, so it's been pretty much an onslaught of water. Tonight I poked my head in the crawlspace under my entryway, and I had 6-8 inches of standing water above the sand floor.
What concerns me most about this is that I have a sump basket on the other side of the house, and although there's been water in there and the pump kicks on several times a day, I haven't actually seen water draining from the tile outlets into the basket. Seems as though the sump is filling from the bottom up. And it appears as though the tile outlets are lower than the water level in the crawlspace, so I'm assuming that water should be draining to my sump rather than rising into my crawlspace.
Luckily I have a utility pump and I was able to drain all but about a half inch of water out of the crawlspace, but now I need to solve a couple of puzzles. Anyone have an explanation on what might be going on, and/or some advice on how to diagnose and fix my problem? There aren't any signs of water damage in the house, so as long as I nip this in the bud I think I can get out of this without too many headaches (I hope).
What concerns me most about this is that I have a sump basket on the other side of the house, and although there's been water in there and the pump kicks on several times a day, I haven't actually seen water draining from the tile outlets into the basket. Seems as though the sump is filling from the bottom up. And it appears as though the tile outlets are lower than the water level in the crawlspace, so I'm assuming that water should be draining to my sump rather than rising into my crawlspace.Luckily I have a utility pump and I was able to drain all but about a half inch of water out of the crawlspace, but now I need to solve a couple of puzzles. Anyone have an explanation on what might be going on, and/or some advice on how to diagnose and fix my problem? There aren't any signs of water damage in the house, so as long as I nip this in the bud I think I can get out of this without too many headaches (I hope).
