I acquired this hot tub when I bought the house I'm in now. Before draining I turned off a 20amp breaker but forgot to turn off the 30 amp breaker to the tub. After filling the tub I was told I have a air pocket and I need to work on getting It out well that didn't work and I drained the tub and filled it through the filter compartment and still a problem. The power light on the control panel flashes only when the 20 amp breaker is on then just after the breaker is flipped I hear a relay on the control box click off or open. Still a flashing light and no success. I was told the heater sensors might be needing to be replaced to correct this problem. Any Ideas????
hotsprings grandee spa problem!!
by halikidHello everyone.
I’m looking into different water treatment options and recently came across Hiju Water Treatment. I’m curious to know...-
Channel: Everything Else
