Door drifting closed
  • lost123
    • Jun 2003
    How do you keep a door from drifting towards the closed position? I don't want to use a stop.
  • Jimmer
    • Oct 2003
    • 274
    Lost123,
    The reason a door swings closed on its own is because the door casing on the hinge side is not plumb. If you place a long ( at least 4 foot) level against the casing you will see this.
    You need to:
    - remove the door trim from both sides of the doors
    - remove any long screws from each of the hinges that go though the casing and into the wall framing.
    - using your level and some shims ( narrow pieces of wood that are gradually tapered to form a wedge) adjust the hinge side of the casing until plumb. Confirm that the door does not close by itself.
    - secure the hinges using long screws to the wall framing.
    - using the door as a guide and shims as needed adjust the other side of the door up/down and in/out to provide a consistant gap between the door and the casing. Secure this side with finish nails long enough the reach the wall framing.
    - re-apply the door trim on both sides.
    Hope this helps, Jim
    • Hube
      • Nov 2003
      • 453
      Lost 123; Sometimes to correct this problem, you only have to loosen a bottom OR a top hinge a touch (1/16") and put a thin piece of cardboard behind the hinge (hinge on door, not jamb) Sometimes this works and sometimes it don't. Good luck, Hube
      • dee
        • Dec 2003
        • 19
        You can also remove a door pin, bend it slightly and reinsert.
        • handyandy
          • Sep 2002
          • 210
          That's a good idea!
