I have just installed a new door knob on an old door. After much frustration and ordering a special part, I got the knob in. Now the strike plate doesn't seem to fit. The door closes, but won't hold securely. Any advice would be helpful.
strike plate problem
the old door had a mortise lockset and its strikeplate had a rectangular cutout for the latch and a smaller similar shaped cutout for the lock deadbolt. a new passage lockset has a strikeplate shaped like the letter D with an extra cutout on the D side with a notch for the primary pin. you need to remove the old strikeplate, fill in the openings from the old plate, then drill out a clearance for the new bolt. the strikeplate may need to be mortised into the door frame with a chisel so it lays even with the door jamb.
by halikidHello everyone.
I’m looking into different water treatment options and recently came across Hiju Water Treatment. I’m curious to know...-
Channel: Everything Else
