Kenmore Ultra Fabric Care dryer
  • chappy1243
    • Feb 2004
    My dryer will only run for about 1-2 full minutes before it cuts off. You then have to wait for a couple of minutes and you can start it again for another 1-2 minutes before it cuts off again. It seems to be just starting to heat when it cuts off. Is this some sort of safety (heat) switch or bad sensor? Thanks to all for any help you can provide on how I can fix this.
    Model# 86982800 69828 Serial# M90709436
    chapman2c@earthlink.net
  • FreeApplianceRepair
    • Feb 2004
    • 69
    Hi,
    There is a overload safty switch that is built into
    the motor.
    If the motor gets to hot is kills the power to the
    motor until it cools off again.
    How old is the dryer?
    Does it sound like it start hard?
    Most of the time when the dryer overload starts cutting
    out it's time for a new dryer motor.
    You could take it apart and make sure nothing fell down
    the lint trap chute and got down into the blower fan.
    If something go down there it could have got around the
    fan blade making it harder for the motor to turn.
    To do this you would have to remove the back of the
    dryer. Then remove the lint chute that the lint trap
    slides into.
    You could also check to see if the dryer motor has a
    lot of lint built up on the motor itself causing it to
    get hot.
    You can check the motor from the front of the dryer.
    Let me know what you find,
    John@FreeApplianceRepair.com
    www.FreeApplianceRepair.com
