Fridge not cooling but freezer works – common causes and fixes
  • machinist
    Moderator
    • 386
    If your fridge isn’t cooling but the freezer’s still working fine, here are a few possible causes and things you can check:
    1. Air vents might be blocked
      Cold air from the freezer flows into the fridge through vents. If those vents are blocked by food or iced over, the fridge won’t stay cool. Check for frost or anything blocking airflow.
    2. Evaporator fan not running
      This fan moves cold air from the freezer to the fridge. If it’s not spinning, the fridge section won’t cool. You can usually hear it running when the freezer door is closed. If it's quiet, the fan might need replacing.
    3. Damper control stuck or broken
      The damper controls how much cold air moves into the fridge. If it’s stuck closed, not enough cold air gets in. It’s worth checking to see if it’s opening and closing properly.
    4. Frost buildup on the coils
      If there’s a lot of frost on the evaporator coils, it can block airflow. That usually means a defrost issue — could be the heater, timer, or thermostat not working right.
    5. Faulty temp sensor or thermostat
      Sometimes the fridge thinks it’s already cold enough when it’s not, due to a bad sensor. That can stop it from cooling properly.
    Quick tip: Always unplug the fridge before doing any checks, and if it looks like a bigger issue, it might be safer to call in a pro.
  • DarkKnight
    • 328
    Thanks for the helpful breakdown!
    When checking the air vents on a typical Whirlpool top-freezer fridge, where are they usually located in the fridge section? Are they toward the back wall or near the ceiling?​
    • machinist
      Moderator
      • 386
      Glad it helped! On a typical Whirlpool top-freezer fridge, the air vents in the fridge section are usually located near the top of the back wall, sometimes close to where the freezer floor meets the fridge ceiling. You might also see smaller vents along the sides depending on the model. Just make sure nothing is pushed up against them so air can flow freely.
      • DarkKnight
        • 328
        If those vents are clear but the fridge still isn't cooling properly, would the next thing to check be the evaporator fan?
        • machinist
          Moderator
          • 386
          Yes, if the air vents are clear and the fridge still isn’t cooling properly, the evaporator fan would be a logical next thing to check. This fan is usually located behind the rear panel inside the freezer compartment. It should start running when the compressor is on and the freezer door is closed. If it's not spinning, it could be due to a faulty fan motor, wiring issue, or control board problem.
          Also, make sure the freezer itself is cold enough, as the fridge relies on that cold air being circulated down into the fridge section.
          Hope it helps!
          • Tomhanks
            • 193
            Just wanted to add a few extra things that might help:
            • Check the condenser coils (usually at the back or underneath the fridge). If they’re clogged with dust, the fridge can overheat and stop cooling efficiently. Cleaning them with a vacuum or coil brush can sometimes make a big difference.
            • Make sure the fridge and freezer doors are sealing properly. If the gasket is cracked, loose, or dirty, warm air can leak in and mess with the internal temperature.
            • Listen for the compressor. If the fan is running but the compressor isn’t kicking on, that could point to a bigger issue like a faulty start relay or the compressor itself.
            These are sometimes overlooked but can definitely affect cooling performance.
            Hope this adds to the great info already shared!
            • machinist
              Moderator
              • 386
              Good points. Those are definitely worth checking. Condenser coils and door seals often get overlooked, but they can make a big difference. Appreciate you adding that.
              • Downaski
                • 409
                Helpful stuff, thanks for sharing!
