I installed a gas oven by tapping into my 1/2" water heater line and running about 7' of 1/2" line to my new 30" stove/oven.
However, the oven takes at least an hour to heat up to 450 degrees. It should take 15 minutes.
Is it possible that a 1/2" line does not deliver sufficient natural gas for an oven? The oven is 15 years old, but has been in storage for 14 of those years. The burner stays lit for well over an hour to "preheat" to 450 degrees. I'm using an external digital oven thermometer to check.
Thanks in advance for you help!
