I have a Kenmore washing machine, model # 110.28902790. It's banging on spin, so I'm going to replace both sets of wear pads. I watched the video, and I'm good until it comes to "use a 7/16 socket to remove the bolt and washer" inside the agitator. Mine doesn't have a bolt. Or a screw. Or anything that looks removable. There's just a pencil-thick smooth, round, flat metal piece inside. I don't see anything to loosen or remove. Help?
How to remove agitator in Kenmore Washer?
the plastic part with the rectangular cutouts in it IS the nut. The metal part in the center is threaded. Make a spanner that will fit two opposing cutouts. Either machine a spanner out of solid steel or weld keystock the appropriate spacing on a solid steel bar. -
Thanks for letting me know which part you had to take off. After looking at it, it looked like the square hole might be a good fit for a 1/2 inch socket extension. Put it in there, fit perfectly, was able to spin that plastic piece off no problem. Thanks again.Comment
Channel: Appliances
