Kenmore Coldspot 106.65882400 not working
  • JohnnyP
    • Oct 2011
    I have a 6yrs old kenmore coldspot model 106.65882400 that doesnt cold at all both top and bottom. both fans are running and no clicking noise. I did some research most said to replace the start relay by the compressor. So i order the start relay from sear and it only came the black(2holes) part, it didnt came with the other(white 1hole) part. so i replace with the new part and let it running for an hour and still nothing. i did the test on the relay with a ohm meter with the new one and my old one they both the same(good). I dont know wat to do next can someone please help me it been 2 weeks without a fridge.
    thanks
    I can find no listing for such a model number. Please double check it.
    both fans are running and no clicking noise. I did some research most said to replace the start relay by the compressor. so i replace with the new part and let it running for an hour and still nothing.
    Did anyone confirm if power was getting to the compressor when the fans are running?
    Appliance411.com
    • JohnnyP
      • Oct 2011
      it a canadian model and serial number is ER4135425. No i didnt check see if there power to the compressor. How do you check to see if the compressor get power. i shook the white part it sound like something loose inside.
        it a canadian model
        That would likely be why it wasn't listed. Sears Canada does not make their parts information available to outsiders.
        That is the overload protector. It is likely defective if it rattles.
        Appliance411.ca
        • JohnnyP
          • Oct 2011
          ya bought the parts today put them back together and it work thanks a million Dan i got my fridge back thanks again..
            Fixed
            Glad to hear it. Thanks for the follow up.
            Appliance411.com
