Our 4 year old Whirlpool refrigerator ET1MHKXM006 just does not get cold any more. When we turn it on we can feel the fan blowing in the freezer compartment and we hear a soft click, the light dims for a second, and then another click a few seconds later. Sounds like something (compressor?) is supposed to turn on but it doesn't. This is the extra refrigerator we keep downstairs for overflow. Does it pay to try and fix, or just replace with a new, basic model? Thanks for any help. Storm
Whirlpool Refrig ET1MHKXM006 Not Cold
Compressor not starting?
That sounds like what is happening, yes. The compressor trying to start but failing and then it clicking out on its overload protector until it has a chance to cool and reset at which time the cycle would start all over again.Sounds like something (compressor?) is supposed to turn on but it doesn't.
Without the compressor running (which it should do whenever the fans are running) no cooling can take place.
Whether it is worth fixing will depend on what turns out to actually be causing the problem. I would definitely say that should be checked out before just scrapping it. It may be relatively inexpensive to repair.Does it pay to try and fix
The compressor not starting could just be due to a failed starting relay assembly (see the following link) or a problem in the compressor itself. It will be difficult for a layman to totally rule out a compressor problem. It might need to be inspected by a professional.
LINK > Whirlpool ET1MHKXMQ06 Compressor Relay Asm.
If it is the compressor clicking on and off, it should NOT be allowed to continue. Disconnect power from the appliance until it can be serviced. Allowing it to continually click on and off could damage the compressor... if it isn't already the cause. If the compressor is or gets damaged, the fridge would not likely not be worth repairing.
Appliance411.com
.Last edited by Dan O.; 02-02-2012, 03:01 AM. -
Gonna Try and Fix It
Thanks for the quick help. Yes, it is turned off. I only heard the clicking when we tried to turn it back on for a couple of minutes. Thank you so much for the guidance. Now, we just have to try and find a repair person who is good...Comment
Since it is a Whirlpool appliance I would recommend a Whirlpool factory authorized (see the link below) service depot.Now, we just have to try and find a repair person who is good...
LINK > Appliance411: Who To Call For Home Service?
You can find Whirlpool service depots at the following link. I would suggest a local company if available.
LINK > KitchenAid, Whirlpool and Roper Service Locator
JFYI
Appliance411.com
.Comment
Channel: Appliances
