Maytag Oven Door
  • dtjacob
    • Jul 2012
    • 23
    Maytag Oven Door
    Hi:
    I have a Maytag range which my wife sprayed stainless steel cleaner thru the vent at the top of the oven door.......now we have all kinds of crud between the inner & outer glass panels. Does the door dis-assemble so I can clean the glass???? Looks like it might, but I'm not going to try until I know for sure.
    Thanks,
    Don
    range oven door
    go to this site:
    REPAIR CLINIC DOT COM
    Look for your range and find an expanded diagram. It should show how the door is put together.
      Yes, the oven door on a stove comes apart to replace parts or clean inside if necessary. The door should usually be removed from the appliance to service it. Look in the owner's manual for how to go about removing the door on your model.
      JFYI
      Appliance411.com
      • dtjacob
        • Jul 2012
        • 23
        Thanks for the info. Thought I could do this, just wanted to be sure.
          It's usually not difficult. There are usually just a couple screws holding the inner and outer door halves together so you can get to the interior surfaces.
          JFYI
          Appliance411.com
