Replacing kitchen range with double wall ovens.
  • KC67
    • Apr 2015
    Hello,
    I'm beginning a kitchen remodel and intend to replace the existing electric range with a combination of gas drop in stove (different location) and double wall oven. I want to use the existing circuit for the new double oven.
    The existing range has a 50 amp breaker.
    The future new double oven ( GE Profile PT9550SF ) requires only a 40 amp breaker.
    House was built in 1998
    Can I use the existing 50 amp breaker or do I need to switch it out with a 40 amp? If I need to switch, can I at least use the existing larger gage wire?
    The future double oven requires only a 40 amp breaker. Can I use the existing 50 amp breaker or do I need to switch it out with a 40 amp?
    The breakers need to be changed. Over-fusing an electrical circuit can be dangerous.
    I'm not an electrician but I wouldn't think the wiring to the oven should need to be changed. If that wiring was even over-sized, it shouldn't present any problems and might actually be marginally safer.
    Appliance411.com
      use the existing wire, just change out the breaker
      • KC67
        • Apr 2015
        Thank you Dan O. and HayZee518. I'll just switch out the breaker.
