WTW5640XW0 Cabrio Washer motor getting hot
  • vipmaint70
    • Nov 2012
    • 19
    I need some help with a washer that I am working on for a customer. He has a WTW5640XW0 Whirlpool Cabrio Washer...its the vertical modular washer type, not the one with the stater motor. His complaint was that the washer would get stuck in sensing mode and not agitated or fill with water. I troubleshooted the unit using the diagnostics mode, the control board tested ok...and the motor test was ok. I physically tested the motor and found the motor was shorted to ground and you could smell where it had gotten hot. I also tested the capacitor it was a 50uf capacitor...it tested 53uf. I ordered a new motor and replaced it. Washer then worked as it should filled with water and agitated but then i could smell the new motor getting hot as well. suspected the board so i replaced it and the actuator motor as well...also took apart and tested the cam mechanism and removed and tested transmission and replaced seal and tub nut assembly. tried the washer now and it runs fine works as it should only thing is the motor is getting hot...hot to the touch. what could be causing this...i am stumped.&nbsp; need some help!<br>
    <br>
    <br>
  • machinist
    Moderator
    • 386
    Hi!
    Although this question was asked a while ago, it’s still relevant for anyone experiencing a similar issue, so here's a potential solution. If the motor is getting hot even after being replaced, there could be excessive load or friction in the drive system, like in the transmission, bearings, or pulleys, which would overwork the motor. It’s also worth checking the voltage to ensure it’s within the proper range and that all wiring and connections are solid. Even though the capacitor tested fine, slight variances under load could cause the motor to overheat. Lastly, check that the motor’s cooling system or fan is functioning properly to prevent heat buildup. Hopefully, this helps someone facing a similar issue!
