Maytag icemaker dripping water
  • paulandjing
    • Oct 2005
    • 8
    I have a Maytag top-mount fridge model# MTB1954ARW, installed with an aftermarket icemaker model# UKI1000AXX 8 years ago. The icemaker is still making ice but has started dripping water. Is there anything I can do to fix it. If not, is it easy to install a replacement icemaker? Thanks for your help.
    ** The icemaker is still making ice but has started dripping water. Is there anything I can do to fix it. **
    A start will be trying to determine *exactly* where the leak it is originating. If you post that, someone may be able to offer further suggestions.
    ** is it easy to install a replacement icemaker? **
    It would likely be less complicated but definitely shouldn't be any harder than was installing the original.
    ** installed with an aftermarket icemaker model# UKI1000AXX **
    That isn't an 'after market' product, it is a genuine Maytag part. It is however an optional accessory for your model. The current replacement kit is # UKI1500AXX (see the link below). Not all the parts in the kit would need to be installed.
    - Maytag UKI1500AXX Icemaker Kit
    LINK > http://www.appliance411.com/data.php?rc=792237
    JFYI
