Kenmore dryer drying time problem
  • kamelion2000
    • May 2006
    I have a Sears Kenmore heavy duty plus dryer
    Model 110.86580100 then a # by itself 65801
    Dryer works fine EXCEPT, it takes at least 2 cycles to get any type of clothes completely dry, including the baby's clothes. I always used the timed cycle b/c I don't think the automatic one (more dry, less dry) senses the tempurature anymore. The timed dry starts at 50 minutes.
    Needless to say, it takes forever to do the laundry because it takes so long for the clothes to dry.
    The clothes get quite warm/hot so I don't think it is a temperature problem. The exhaust hose is new and is vented well.
    Any ideas?
  • Dan O.
    • Sep 2003
    • 2167
    [Kenmore dryer] takes forever to do the laundry because it takes so long for the clothes to dry. The clothes get quite warm/hot so I don't think it is a temperature problem. The exhaust hose is new and is vented well.
    Any ideas?
    Yes, the most likely cause IS usually poor or improper venting (see the following link), regardless of the vent's age. How long is it and how straight??
    LINK > How long can my dryer vent be?
    If that's definitely not the problem, than poor air flow through the dryer is likely the cause. Poor air circulation can be caused by worn drum seal(s), a plugged lint filter, a broken or slipping blower fan, lint filter out of place or other leaks in the dryer's internal ducting. There isn't much else that can cause poor drying if the dryer is heating properly.
    LINK > 110.86580100 Rear Drum Seal
    LINK > 110.86580100 Blower Fan
    LINK > 110.86580100 Link Filter, White
    JMO
    • kamelion2000
      • May 2006
      more questions
      we checked the lint area - not it
      made sure the exhaust hose had a clear and straight path and was not blocked by lint
      the blower fan appears to be fine
      the seal appears to be fine - but not sure how to tell
      found an adjustable knob marked A-E next to the lint cover, it was set on D and we turned it up to E.
      So now, if the heating is the problem, it could be the element or the thermostat. How do we tell which one? Or should they both be replaced at the same time
      Turning up the element to E helped somewhat
      Thanks for all the info
      • Dan O.
        • Sep 2003
        • 2167
        Did you try running the dryer *with the vent totally removed* for a load or two as was suggested at the page I linked to? That is usually the best way to totally eliminate the venting as a possible problem.
        Not frayed or falling apart at all? Can you tell if it appears to be sealing against the bulkhead?
        LINK > Kenmore 110.86580100 Rear Drum Seal
        Usually a dryer element will either work or it won't. It could possibly get shorted to ground and only generate 1/2 heat (or less) but that would often also cause the element to stay on (partially) even when the dryer was off (a dangerous condition!). The element would have to be inspected to see if that was the case.
        LINK > Kenmore 110.86580100 Heater Element
        It is also not very common for thermostats in dryers just to get out of calibration and continue to operate but at the wrong temperature. They more often fail opening completely resulting in no heat at all or shorting closed causing overheating.
        Or should they both be replaced at the same time?
        I don't usually recommend people just replace parts willy-nilly. If you're unable to isolate the likely caused within a fair amount of certainty, I suggest you call in a professional that can. JMO
        found an adjustable knob marked A-E next to the lint cover, it was set on D and we turned it up to E... Turning up the element to E helped somewhat
        I'm afraid I'm not sure what that feature is. If its the adjustment for the electronic control, it would likely only affect the advancing of the timer (making cycles run slightly longer or shorter depending on its setting) and not affect the actual heat (I'm not aware of any feature on a modern dryer that would). It would also only be in affect during an 'auto' or 'permanent press' setting, not regular timed cycles.
        JMO
        • wak
          • Feb 2006
          • 33
          The entire exhaust duct culd be filled with lint. Hence why the other gentlemen said to run it without the duct connected.
