I have the same model electric oven (maytag CWE9000ACB)with the same problem as ohara6z91. We have replaced the oven sensor probe and that did not fix the problem. the lower bake element seems to work and the broil also heats up when you switch to broil but the bake temp is WAY off (about 75-100 degrees) we dont own an ohm meter. should we buy one and start checking things out?
Maytag Electric Oven Problem
Tags: None -
Well there's only 2 things that can be responsible for the oven temperature being out, the oven sensor or the electronic control. Since you say you replaced the sensor and the symptom is still the same, that just leaves the electronic control?Originally posted by suesuethe bake temp is WAY off (about 75-100 degrees)
Not quite, theirs doesn't heat above 220 when set on 550!same problem as ohara6z91
That's considerably different than only being out 100°?
There's not a lot of checking that can be done for such a symptom. The sensor would be one but if it's new, I would be leaning toward it being good. As long as the element(s) glow red when the oven is turn on, they are doing all that can so that just leaves a defective control which can't be checked itself.we dont own an ohm meter. should we buy one and start checking things out?
You're certain whatever you're using to judge the actual temperature is accurate? Cheap, store bought oven thermometers are notorious for being inaccurate.
=D~~~~~~ -
It is a cheap store bought oven thermometer I am using to check the temp. But it is probably pretty close based on the time it is taking to cook things now vs. when it was working correctly.
I was hoping you weren't going to say the electronic controls because from what ohara6z91 said these arent even available anymore and even if they are I am sure they are pretty expensive. probably not worth putting that much money into at the age it is. (14 years old).
sounds like I may be going oven shopping this weekend.
Yes, some controls can however be repaired/rebuilt. There is one company I know of that specializes in that, you can find them listed at the following link:Originally posted by suesueI was hoping you weren't going to say the electronic controls because from what ohara6z91 said these arent even available anymore
LINK > Appliance411: Appliance Links: Restoration
Electronic controls often cost $150-250+ new.and even if they are I am sure they are pretty expensive.
=D~~~~~~Comment
thanks for the link for the place that may be able to rebuild the controls. I will check that out.
a coworker of mine mentioned that the broiler element should turn on during the bake cycle. I don't think mine does. it does work during the broil cycle though. do you think this could be bad?
and another question.....could I just adjust my temperature and keep using my oven? I could just set the oven the 100 degrees higher than whatever the recipe calls for? or would that cause other problems? I would like to hold off on replacing as long as possible.Comment
On most ovens, the broil element is only used during the initial 'pre-heat' cycle of a bake. After that only the bake element cycles on and off to maintain temperature.Originally posted by suesuethe broiler element should turn on during the bake cycle.
No. An electric range/oven element will usually either work or it won't, all the rest is determined by the control. If the element is working at all, it is likely good.I don't think mine does. it does work during the broil cycle though. do you think this could be bad?
LINK > How do I test an electric stove element?
An oven can usually still be used when the temperature is out... depending. Unfortunately, most electronic controls will not allow you to adjust the temperature display more than ~ +/-35°F. Check you owner's manual.could I just adjust my temperature and keep using my oven?
I can't see why that wouldn't work. Hopefully the amount the temperature is out stays uniform and does not creep up over time.I could just set the oven the 100 degrees higher than whatever the recipe calls for? or would that cause other problems?
I however would suggest you NOT leave the range unattended while in use just in case of some other type of control malfunction occurs.
I would further suggest you NOT use the self-clean feature as the oven normally gets to 850°F+ during a 'clean' cycle. Who knows what might happen if the control doesn't know what the true oven temperature is at.
=D~~~~~~Comment
