Whirlpool washer will not spin
  • Dean1952
    • Aug 2006
    I am a new member and may not have completely searched previous post on this topic.
    I have a Whrilpool washer model LSN 100HQO, it suddenly gets to the spin cycle and quits. THe tub is full of water, and it is not makeing any noise.
    thanks
    Timer movement
    Originally posted by Dean1952
    Whirlpool washer model LSN 100HQO
    Maybe LSN1000HQ0?
    Does the timer advances through the rest of the cycle to the end?
      if the timer seems ok check the solenoids under the tub on the transmission. if the plungers do not pull in then the tub won;\'t spin.
      • Dean1952
        • Aug 2006
        The Timer does not advance, it stops before any water is pumped out. Does this indicate a Timer problem. Is the solution a new TImer. Thanks for the replies.
          Model number?
          check the solenoids under the tub on the transmission. if the plungers do not pull in then the tub won't spin.
          That would only apply to older, belt-drive Whirlpool washer models. The OP's model (if it really is LSN1000HQ0) should be a 'direct drive' (ie. beltless) washer design.
          Than you may have a problem in the washer's lid switch (see the following link) or that switch's actuator. The washer will not advance to the drain/spin portion of the cycle unless it can detect that the lid is closed, as a safety precaution.
          LINK > Whirlpool LSN1000HQ0 Lid Switch
          PS. Did you double check the model number so we can be sure what appliance you're dealing with???
          • Dean1952
            • Aug 2006
            It was the Lid Switch. Wife forgot to mention she had stuck a screwdriver in the hole, and switch gave way.
            Thanks for the help
