Kenmore Dryer Problems
  • GTOKID
    • Jan 2007
    We have a Kenmore Model 417.94152500 front load dryer, which is almost 2 years old. Every once in a while, the dryer would not start in the evening. However, in the morning, it would fire right up. Now, this problem is happening almost all the time. Need some troubleshooting ideas - thanks.
    As I replied to your other forum message:
    I can not think of any problem that would cause a failure in the evening but not the mornings. It is likely just coincidence.
    : Need some troubleshooting ideas
    Someone might need check to see if the motor is getting power. If it WAS getting power when it should be running but wasn't, the motor would likely be defective and need to be replaced.
    LINK > Kenmore 417.94152500 Dryer Motor
    If it was NOT even getting power, its wiring circuit would have to be traced to see where the stoppage was.
    Did anyone yet confirm the dryer was at least still getting power at the time of the failure?
