i have worked recently with the new lg refrid. lrsc26905tt
the compressor was having starting issues. the unit would not run or start the compressor at all. the compressor was changed. i replaced it with a new compressor. the compressor seemed to work at first during the charging. i filled the system to the manufactes reommended freon level 4 ounces. the compressor started. i finisheed the fill . i pulled the plug and waiting 10 or 15 minute to try to restart the compressor. the compressor now will not start. the overload has kicked out. i was not sure if i have a vapor lock or if some one has come across this issue before. the unit was vacumn down and recharged as far as i know correctly. does anyone have an ideas or tips?
