Whirlpool washer not spinning
  • GoHorseGo
    • Jun 2007
    2001 model LSQ9665JQ1 S/N CL0503223
    I have a top load whirlpool washer that won't spin. It'll pump water and sounds like it's spinning but no spin.
    I have replaced a warn out round rubber cuppler between the motor and transmission.
    I have replaced the transmission.
    It worked for 1 load after the transmission replacement but now nothing.
    It will spin by hand, hard, but can turn it.
    What is my next logical part replacement and is there a parts breakdown anyware on the net for this washer?
    Thanks,
    GoHorseGo
    Originally posted by GoHorseGo
    [Whirlpool washer] model LSQ9665JQ1 won't spin. It'll pump water and sounds like it's spinning but no spin.
    Does the timer pause the motor between drain and spin?
    - See "Spinning" and "Motor Runs but No Spin" at the following link.
    LINK > Whirlpool Direct Drive Washer
    is there a parts breakdown anywhere on the net for this washer?
    LINK > LSQ9665JQ1 Exploded Parts Views
    JFYI
    • GoHorseGo
      • Jun 2007
      Yes,
      It even "sounds" like it's spinning. I can tightning things up, and it'll go for about 1 wash, then quit spinning.
      I'm thinking either the break assembly or the block/spanner nut. But was trying to trouble shoot it so I don't put too much money in it.
      Jack
