Badger 5 Prblems
  • Bob Johnson
    • Dec 2003
    Badger 5 Prblems
    Hello,
    I am having some problems in regards to my sink draining. I can run the water for a while, but soon enough the sink fills up and drains painfully slow.
    There is nothing caught in the garbage disposal, and when I run it it makes the normal noises, but while it is running it pushes water from the left hand side to the right. Once I turn it off, all the water goes back to the left side. I took apart all the pipes I could, and there was nothing caught in them.
    Any help would be much appreciated.
    Thank You.
  • albright
    • Feb 2006
    • 16
    disposal
    i would recommend removing the p trap so that you can use a drain snake to remove the clog. a tool like this: http://plumbing.hardwarestore.com/51...er-195297.aspx
