Dishwasher will not drain
  • lbt007
    • Dec 2003
    My dishwasher will not drain.
    I know my drain pipes are not clogged because I remove the DW drain hose from the garbage disposal to let it drain into a bucket. I made sure it went all the way up to the bottom of the countertop and down again. No water came out of the drain hose.
    Next, I pull the DW out and remove the drain hose of the DW at the back. Water drained out from that hole by the bucketful. So I check the DW hose. No clogged.
    How are DW suppose to drain? Is there a pump or something that pushes the water up into the drainhose that is broken?
    b.t.
  • Hube
    • Nov 2003
    • 453
    It could be the PUMP is at fault, or a faulty main control.
    • irregularjoe
      • Nov 2003
      • 176
      [quote]Originally posted by lbt007
      b.t.
      [/quote
      You are sure that the plug is removed from the disposal, right?
