My gas dryer started humming this morning when you start it up. If I open the door it stops, I close the door and about 5 seconds later you hear the gas flame ignite. If I open the door again the flame shuts off. What should be my next step?
Gas Dryer humming
Make/Model number??
What is its brand name and model number so we can look up what appliance design you're dealing with?My gas dryer
Humming from where on the machine exactly?started humming this morning when you start it up.
Was it running??
Just about everything in a dryer that is powered will stop when the door is opened.If I open the door it stops
Even before the dryer is running????I close the door and about 5 seconds later you hear the gas flame ignite.
1. Post the product identification information.What should be my next step?
2. Identify exactly where any strange sounds are coming from.
3. Describe the symptoms more accurately or in more detail.
If you can supply that information we'll see if we can suggest possible cause(s) or a course of action.
=D~~~~~~ -
The make and model are:
Whirlpool Ultimate Care Heavy duty
Model: LGL8858EQ0
The humming comes from the bottom, it sounds like. Now when I close the door and even though the machine is not on, I hear the flame ignite. Not wanting to leave it that way, I am leaving the door in the open position for now. The machine is not running, when you hit the button to start, the humming starts
I opened the back of the dryer and the front, the belt is still intact, not broken or loose. The motor shaft still spins ok, any other items I should check?Last edited by rennyboy; 02-14-2008, 02:54 PM.Comment
Motor problem?
Good.Whirlpool [dryer] model LGL8858EQ0
Maybe from the motor?? There shouldn't be too much else toward the base of the dryer which could be responsible for sounds. It's either that or maybe the gas burner assembly.The humming comes from the bottom
Yes, that is likely the motor trying to run but failing... for whatever reason.The machine is not running, when you hit the button to start, the humming starts
There should a separate contact in the dryer motor's switch for the heater circuit. That contact should remain open until the motor is running and up to speed. The heater should not be energized without the motor running.when I close the door and even though the machine is not on, I hear the flame ignite.
Maybe the motor's switch is internally defective allowing the heater to be on when it shouldn't and also preventing the motor from running? If its actuation mechanism isn't just jammed up with lint, etc., the motor might need to be replaced.
LINK > Whirlpool LGL8858EQ0 Dryer Motor
I would suggest you go one step further and actually unplug the machine until it can be looked into. Better safe than sorry?when I close the door and even though the machine is not on, I hear the flame ignite. I am leaving the door in the open position for now.
=D~~~~~~Comment
Channel: Appliances
