Kitchenaid Dishwasher problem HELP
  • Ben
    • Dec 2003
    Hi all,
    I have a kitchenaid dishwasher (sorry I dont know model number because I am renting a place) it is currently stuck in the middle of a cycle (water on the bottom pan). It will run for about 30 seconds and then shut off. The cancel/drain botton does nothing. I want to drain the washer and abort this cycle...I've killed the power at the breaker trying to clear it out that did not work. I had a similar problem six months ago called a repairman, of course it worked for him.
    If there is anyway I can just reset the timmer motor or if anyone has any idea I need them.
    Thank you very much
    -Ben
  • FreeApplianceRepair
    • Feb 2004
    • 69
    You want to remove the bottom panel and take a look at the motor.
    See if it looks like it has been getting wet.
    The pump/motor seals leak and then get the motor wet.
    I see it all the time.
    John@FreeApplianceRepair.com
    www.FreeApplianceRepair.com
