Whirlpool Dishwasher
  • popgun2k
    • Nov 2003
    • 5
    Hi
    I have a Whirlpool Dishwasher(under the counter).I went on a vacation and shut the water off to the dishwasher,just in case of hose break.When I returned home the other day,I turned the water back on and tried to run the dishwasher.It would not spray any water or no water would come thru the cycle.Too much of a coincidence,by just shutting the water off,as the dishwasher was working fine before I left.Any suggestions would be appreciated
    tks
    Model number?
    Whirlpool Dishwasher (under the counter)
    I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number.
    If no water is entering the machine, no it won't have anything to spray.
    Too much of a coincidence, by just shutting the water off
    Just shutting off the water supply to the dishwasher should not usually cause any problems in a dishwasher. It has to be coincidence.
    A start in trying to determine the cause will likely be to see if the dishwasher's water fill valve is getting power when it should be filling. You can read how the water valves on appliances function at the following link:
    LINK > How do I test a water fill valve?
    JFYI
    • popgun2k
      • Nov 2003
      • 5
      Hi Dan
      Sorry for no info.Here it is.
      It is a Whirpool Power Clean
      Model#-WEU37001
      Serial#-FD4611683
      Hope this helps
      Tks for reply
        Canadian Whirlpool Dishwasher
        Whirpool [dishwasher] model WEU37001
        That model is a Canadian Whirlpool product.
        Hope this helps
        At least I now know what machine design you're dealing with. Now some actual testing on the appliance will be required to try to isolate the possible cause.
        You can see what the water fill valve on your model looks like at the following link. That is where testing will likely need to start.
        LINK > Whirlpool WEU37001 Fill Valve
        www.Appliance411.ca
