Hi,
I did no take a peek yet at the model # for now due to the access. But on the washing machine the labels are 'Kitched-Aid SuperBa SureCare 3 Speed Whisper Quiet'. It is a Cdn model anyways, so it may not be identifiable in this forum.
Basically, it works fine during the wash cycle, but during rinse the tub will not spin. I hear the motor working but when I lift the lid, I do not see the tub moving at all.
I checked the balance and it looks good from left - right and front to back. Another observation is that looking down at the tub, the outer-rim seems off centre from the opening (where the lid rests). I can move the tub in all directions, I don't know if this is normal or it should be more rigid?
I have checked the symptom flow chart and many causes are listed but I would rather have someone suggest a more probable cause and solution.
- water level switch?
- motor coupler?
Regards,
Gus
- motor coupler?
Regards,
Gus
