What is the difference between 2 water pump p/n's: AP2907492 and 3363892
  • dieselgg
    • Sep 2008
    • 12
    Could someone please tell me what would be the difference between the 2 following p/n's for a water pump that goes in a Kitchen -Aid Direct driver washer Cdn model YKAWE777BW1 (Kitched-Aid SuperBa SureCare 3 Speed Whisper Quiet)
    - AP2907492 < --- is this # obsolete
    - 3363892 (original Whirlpool p/n)
    On ebay I also found a Supco brand pump, on the package it saids P/n LP121 replaces 3363892. Is this the real deal, quality part?
    Regards,
    Gus
  • dieselgg
    • Sep 2008
    • 12
    Ok, I figured it out. The AP p/n has the smaller port on it.
      Whirlpool washer pump differences
      Obsolete??? It appears to still be available and likely will be for many years to come yet. It is the most popular pump used on Whirlpool built washers.
      LINK > AP2907492 Standard Washer Pump Asm.
      The AP... p/n has the smaller port on it.
      Yes because that pump is missing the internal flapper valve of the other which prevents waste water from backing up into the washer's drain system and that also reduces the amount of noise the pump generates during non-drain functions.
      LINK > Whirlpool FSP 3363892 Washer Pump w/Check Valve
      I also found a Supco brand pump. ..quality part?
      That is an 'after market' replacement part. I would think it should work satisfactorily but do not know of its comparable life span. I however usually suggest sticking with genuine OEM factory replacement parts whenever possible (see the following link) unless there is no other choice or are other very compelling reasons not to.
      LINK > Repair Parts: OEM vs. Generic Brand Parts
      www.Appliance411.ca
      • dieselgg
        • Sep 2008
        • 12
        Thanks Dan for all the information you provided.
