GE ice flap and ice auger problem
  • mission
    • Oct 2008
    • 15
    I have a side by side GE stainless refrigerator that keeps having the ice auger motor freeze up. I can thaw the motor with a hair dryer but it will freeze up again shortly. I think the ice dispensor flap in the door is the problem because it is partially open letting warm air into the freezer creating a build up of frost. I am trying to figure out how to get to the flap. I took off the trim around the dispenser and removed the screws but the dispenser unit will not come out of the door. Any suggestions??
    Thanks
    Model number?
    I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number.
    Forum Instructions Link > Please include Make and Model # in post
    If you post that information someone might be able to answer your question or at least look up to see which GE refrigerator design you're dealing with. They're not all the same.
    • mission
      • Oct 2008
      • 15
      The model number is TFS25 PPBB BS.
        Front serviceable?
        model number TFS25 PPBB BS... the dispenser unit will not come out of the door.
        The closest model number I found a listing for was TFS25PPBEBS. On it I do not believe the dispenser assembly is removable. It should be front serviceable (see the following link).
        LINK > Newer GE fridge dispenser
        The solenoid on such a dispenser can rust causing problems with the chute door.
        LINK > GE TFS25PPBEBS Dispenser Solenoid
        If interested you an see exploded part view diagrams for the model number I listed at this link:
        LINK > GE TFS25PPBEBS Exploded Parts Views
        JFYI
        • mission
          • Oct 2008
          • 15
          OK, the information so far has been great. I was able to access the ice chute through the front of the door. I noticed that I could close it manually by wiggling it a little. If I open it like if ice was going through it, it will stay open just slightly. It seems something on top of the solenoid pops up and interferes with the chute closing all the way. When this occurs, warm air enters and causes frost. How can I determine if this is a solenoid problem?
            Solenioid...
            Easy fix. Remove the screws holding that solenoid. I think there may be two or three Phillips heads doing that. Unhook the solenoid from the flapper door hook. Clean the solenoid plunger from the soft rust that's built up on it. Also clean out the inside of the solenoid coil as clean as you can get it. Lubricate it with a THIN film of light grease. The grease will help keep it from getting rusty again preventing proper operation. It's a difficult place to keep condensation from forming and rusting stuff back up. BUt it's an easy enough fix that even if you'd have to do it again in a couple years, it's not a big deal. Also, replace those Phillips screws with stainless ones. Just can't figure out why companies don't use stainless around appliances that use water.
            • mission
              • Oct 2008
              • 15
              This sounds like a great fix. I will get on this tomorrow night after work and let you know how it went. It's exactly what I need to do tomorrow for some satisfaction! Just a question though, do you think this might solve my auger motor freezing up or should I order the auger motor boot part from GE that covers the motor to protect it from freezing again?
                Ice auger...
                I'm stepping into Dan O's territory here. Not all THAT knowing! I guess it may be possible for the ice to bog up at the front to keep the auger from doing it's job. That's what was happening to ours 'till I brought the solenoid back to life. Hope Dan corrects me when I'm wrong....
                  Moist air infiltration into the freezer compartment could alone cause the motor freeze up.
                  I do not believe the auger motor on the model I looked up has any 'boot' associated with it anyway. The 'boot kit' GE came up with most recently was for their electronically controlled Arctica and Eterna refrigerator designs, not yours AFAIK.
                  LINK > GE Arctica and Eterna Auger Motor Boot
                  I do not know whether it would fit on your model (although the motors do look similar) and I don't know of any other boot that is available. It might be worth a try if that symptom returns after the other problem has been resolved or if you have to order parts for the other repair anyway. The boot isn't very expensive.
                  PS. Did you double check the model number?
                  • mission
                    • Oct 2008
                    • 15
                    Yeah, funny thing, I double checked the model number and I am correct as the model number I read is off the fridge on the lower right front. But every time I tell a parts dept, no one can find that model number. Mystery.
                    The frost build up is solved with no air getting into the freezer. I just haven't thawed out the auger motor since I fixed the solenoid problem. I hope to get to this when I am back in town next week.
                    Thanks for everyone's help...you guys are great!
                      Fixed
                      I double checked the model number and [it is] correct. But no one can find that model number.
                      It looks correct and fits in series with other GE fridge model numbers (see below) but it just isn't listed in any of the GE parts lists I have access to.
                      Found model numbers:
                      TFS25PPBABS
                      TFS25PPBCBS
                      TFS25PPBEBS
                      TFS25PPBGBS
                      The frost build up is solved with no air getting into the freezer [anymore]. I fixed the solenoid problem.
                      So it was only the solenoid. Glad to hear it. Thanks for the follow up.
