Whirlpool Washer drum is out of balance.
  • plmahlik
    • Nov 2008
    • 5
    In the spin mode my Whirlpool washer drum moves around more then normal making a banging sound. It looks like whatever was holding the drum centered in the washer broke loose. What do I do to fix this?
    Thanks, Larry
    take the top off the washer and look for a broken spring that supports the outer drum. the inner drum is what spins.
    • plmahlik
      • Nov 2008
      • 5
      Thanks for the reply
      How is the best way to take the top off?
      Larry
        Before you go on a wild goose chase...
        Whirlpool Washer
        I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post it we can look up to see what appliance design you're dealing with.
        Forum Instructions LINK > Please include Make and Model # in post
        On the most common Whirlpool washer design the top does NOT come off, the whole cabinet is removed for service. But if the OP posts the machine's model number we can look it up to see for sure instead of guessing.
        BTW. Has the machine been moved or relocated immediately prior to this occurrence?
        • plmahlik
          • Nov 2008
          • 5
          The waher is a whirlpool Model number LA7000XTW0
          The machine has not been moved or relocated immediately prior to this occurrence.
          Thanks for the help,
          Larry
          • plmahlik
            • Nov 2008
            • 5
            Whirlpool Manual
            I do have a manual for it. This is the link:
              Whirlpool washer out of balance on spin
              On that model out of balance can occur if the suspension spring(s) (item #3 in the 'Machine Base Parts' illustration of the parts manual you linked to) were broken, weakened with age or just fallen off. Another common cause is worn/broken suspension pads (#'s 16 and 18 in that same illustration).
              LINK > Suspension Spring
              LINK > Suspension Pad, Plate
              LINK > Suspension Pad, Base
              If the washer had been moved or even laid down for some reason, the triangular suspension plate (item #17) could just have just moved out of place.
              Whirlpool washer model number LA7000XTW0
              On that model the whole cabinet (less back panel) is removed for service of internal components. While not for your specific job, you can read about removing the cabinet on that design of washer at this link:
              LINK > Direct Drive Washer Motor Coupler Replacement
              • plmahlik
                • Nov 2008
                • 5
                Thanks for all the help
                Thanks for all the help. I'll get at it tomorrow.
                Larry
