Kenmore #11020056990 Washer
  • Nikita
    • Dec 2008
    Kenmore Washer Model#11020056990 Serial # FD953UI, no power, past year intermitent with the power, sometimes would work, wait a few days then would work. Unplug or shut off power may make it come on.
    In summer called Sears, they say new control panel cost over $300.00 to repair with a 3 or 6 mo warranty and part would be a reconditoned one.
    When repairman was here he slid his finger down the buttons and it came on, so we only used on regular cycle or rinse.
    Now no power for about 4 days, it may come on.
    I'm hopin for a quick fix, but I'm not feeling lucky.
    Looked at new washers, seems they are are going to the front load with the government and their energy policies.
    There are a few models left with the turn knobs, the repair man had said if i get new to buy one with knobs. I don't like the front load.
    Can this be fixed in anyway?
    Over the phone or someone actually there checking it out???
    The only way the problem will be determined is by actually systematically checking it out although an electronic control problem does sound possible.
    You can always hope but if you want it repaired someone is likely going to need to actually look into it to try to determine the cause to see if it can be corrected.
