I have a Sanyo model sc-240 canister vacuum cleaner that I bought about 5 years ago. Today when trying to use it it wouldn't turn on. I tried outlets that other appliances work on. I have never had this problem before with this vacuum. The only diagnosis the manual gives for this problem is to check to see if the cord is plugged all the way in the power outlet and to replace the cord if the cord is damaged where the cord connects to the plug. I have the cord completely plugged in when trying to get it to start, and there is no damage that I can see where the plug connects to the cord. Any replies are appreciated.
Canister vacuum cleaner won't turn on
if the cord retracts into the vacuum cleaner, there's a set of carbon brushes that contact a rotary "commutator" inside the rewind unit. this in turn is connected to the internal wiring with push on spade terminals. you may need to take apart the shell to access the rewind unit. -
I went looking for your specific vacuum. I found that Sanyo doesn't manufacture vacs anymore. Other sites that I did locate your vacuum have discontinued stocking them. The pathway for your power is through the cord, switch and to the brushes on the motor. That's the best I can do being that I can't find a diagram of how to take your machine apart. Otherwise I'd try to talk you through it.Comment
I went checking a little further and what I found was a variable of price ranges for the vac. From $32 to over $132. I also found this pdf diagram of how your machine goes together. Its really quite simple.
by Adam/Ok the model # GTW330ASK0WW has a very, very, very intermittent problem. About once a month I will come in and find the machine has the wash light on...
Channel: Appliances
