Frigidaire refrigerator not keeping temp
  • rennocda
    • Mar 2009
    Hi,
    I have 4 year old Frigidaire side-by-side refrigerator (PHSC239DSB5). Yesterday, I noticed that it was too warm. It has a digital display of the temps. The freezer was around 27 and refrigerator around 50. I pressed the reset button. It continued to run overnight and the temps remained the same. I did not check the temperature with an independent thermometer, but they are about right. So it is working partially, but not getting the temp as low as it should. The temperature settings are at the default settings (0 and 36). Does anyone have any ideas about what the problem might be.
    Thank you
    The freezer was around 27 and refrigerator around 50. I pressed the reset button. It continued to run overnight and the temps remained the same. Does anyone have any ideas about what the problem might be.
    It might be the first signs of a defrost problem as described at the following link:
    LINK > My frost free refrigerator is not cooling properly. What might be the problem?
