Hello. I just replaced the motor and belt on my LDE 410 dryer. The first time I went to try with a full load of clothes the dryer struggled to turn the drum unless I turned it by hand while holding the door switch and the door open. Once I took out a couple pair of jeans it seemed to run alright. I never had this problem before the motor swap. Would putting a stiffer spring on the idler wheel help. My thought it that maybe the belt is slipping some.
My other issue is that now I have a squeaking/rattling noise down by where the motor/belt/tenisnor setup is that I can't seem to figure out as well. Any ideas on what to look for?
Will
Will
