I have this very old gas oven that came with the apartment I'm living in. It's been here since I moved in 5 years ago, but I decided to clean and use it once and for all.
The problem I have is that it has this piece of metal hanging on the back of the inside of the oven. I think it's a thermometer, but I'm not sure since this thing looks so old. Anyone can tell me with it is and if the oven still looks good -from the inside- to use? (the flame under it is always lit, so I had no problems turning it on).
UPDATE: the thermostat is ok, but I have another problem now. The flame in the bottom goes off even though I leave it at 300 degrees F. Every time I try to turn it on again, I have to put it higher and higher and the flame goes off eventually. I think I need to replace something...
