My Ge Nautilus Dishwasher will not open the soap dispenser when it's ran. It was intermittent for awhile, but now it's doing it all the time. I've already checked to see if anything is obstructing it from opening during the wash cyle, but there isn't... any suggestions?
GE Nautilus Dishwasher Soap Won't Open
Model number?
I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post it we can look it up to see what appliance design you're dealing with.Originally posted by GPRace9r8
You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Search
=D~~~~~~ -
Similar problem with my GE Nautilus Dishwasher
My soap dispenser doesn't open until the washing is done. I put soap only in the main dish. After washing is done, I find the soap sitting in the bottom of the washer as if the main dish delayed it's opening for some reason.
My model # is GSD3220FBB.Comment
That model number looks incomplete. Please double check it.Originally posted by v34467
GE dishwasher model # GSD3220FBB.
That is most often caused by the dishwasher not spraying properly... or at all. It is the water spraying that washes the detergent into the tub water so it can be circulated.I put soap only in the main dish. After washing is done, I find the soap sitting in the bottom of the washer
How high is the water level in the tub compared to the heating element, right when it starts washing? Too low of water level can cause poor spraying.
The most common GE dishwasher detergent dispensers (except very new models) are actuated mechanically via a cam on the timer and a lever. The poster's model looks to use that mechanical system.the dispenser lid operates off an electromagnet in the door
JFYI
=D~~~~~~Comment
