i have a maytag gas dryer and it does heat it but just a bit. the model is a quiet plus 2 and you can fel just a bit and not much of the heat. will dry but i have to run it like 3 cycles. any hints what can it be. im very handy and think i can take it apart but before i do some help would be mice.
maytag gas dryer not working
I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number ("quiet plus 2" isn't it). If you post it we can look it up to see what appliance design you're dealing with.maytag gas dryer model quiet plus 2
Forum Notice > Please include Make and Model # in post
A first step in diagnosing heating problems in gas dryers is usually to inspect to see exactly what the gas burner and its ignitor is doing when it should be heating.gas dryer does heat but just a bit.
You can read about how most gas dryer burners operates at the following link:
LINK > Generic Gas Dryer Operation
JFYI
=D~~~~~~Comment
Channel: Appliances
