My 6 year old Whirlpool Gold Conquest side by side fridge, wasnt working this morning when I got up. I heard the relay or whatever it is clicking trying to start it, I unplugged the fridge to let it cool off, I removed the realy from the side of the compressor and shook it, (it has quite a noticeable rattle when shaken as if there is loose rice inside it, I tapped the side of the compressor with a pair of plyers and replaced the relay. I plugged the fridge in and it started and started to cool the fridges interior.
Stupidly I unplugged the fridge a bit later so I could roll it back in postion and it wouldnt start again.
I happened to have a universal relay around the house, (Cant remember exactly why) A little while ago I hooked it up to the compressor and it startted (after a bit of hesitation) and is running and cooling.
what does this mean? is my compressor shot or just a bad relay?
can I damage the compressor by running it with this relay?
I believe I hooked the relay up right, by following the diagram on the side of the universal one, although I am not sure that the wires are hooked to the right post.
What should I do?
Thanks so much
Bill HIggs
What should I do?
Thanks so much
Bill HIggs
