GE side by side noise.
    Unit info: GS25JFMC WW. Serial: FD244841
    Sounds like a fan on the freezer side making a noise similar to the baseball-card-in-the-wheel-spokes, only at higher speed and maybe not quite as loud. But loud enough....
    Easy to get to? Easy to replace? Would that even be the problem? Sounds like it's coming from in bqack of where the freezer light is.
    check for a wire or piece of plastic hitting the fan
      Model number incomplete/incorrect
      [model number] GS25JFMC WW
      That model number is incorrect or incomplete. Please double check it.
      Look for an excessive frost build up on the evaporator coil which could be extending too near to the fan blade.
        'Fridge noise
        Will take it apart and check.
