hi-temp electrode connections (electric range)
  • Bruce A
    • Aug 2009
    Good morning.
    I have a 30 year old Kenmore drop-in electric range with chronic oven electrode connector problems.
    The wires from the control panel are connected to each of the oven (bottom) and broiler (top) electrodes with a simple screw at the end of each electrode leg. Every few years, one of the wires (stranded) breaks right at the screw connection.
    I have tried using hi-temp crimp connectors under the screw, but the wire just breaks at the supply end of the hi-temp crimp connector.
    Is there any other option that would not subject the wire strands to as much flexing?
    Thanks for your time!
    • 8747
    the wires that come off the element are supposed to terminate in nickel/chrome crimp on ring terminal lugs. the wire itself is nickel/silver wire. if you use a crimper nest as in STA-KON terminal crimper you should have no problem. the type of crimper they sell in automotive stores that just compress the terminal will not do. all it does is crush the terminal "round" onto the wire and not impress a dent in the terminal, which is what's supposed to occur.
    • Bruce A
      • Aug 2009
      Thanks for your reply.
      Is there any way of doing the STA-KON crimp with other than a dedicated STA-KON crimper tool? I only need to do it 4 times.
      Also, source for nickel/silver insulated wire?
      Regards from very hot Vermont.
        • 8747
        go to any electrical supply house and ask for silicone-glass insulated wire. size will probably be #12. the sta-kon crimper will probably cost around $35 but Ideal makes an electrical plier with a crimp nest near the fulcrum. tools are expensive to buy but get it once and you'll have it for eternity. even if it means making four splices that hopefully you won't be making again. good luck!
          Take it to a professional?
          Alternately, if you take the original wires to a local appliance parts or repair company, they should be able to install appropriate connectors onto them for minimal charge. That is depending if the wire is still long enough to be cut back slightly first. (Need a good piece of wire to put the connector onto.)
          BTW. If the wires or terminals are burning off, both element and connectors (and maybe wires) should be replaced together.
          • Bruce A
            • Aug 2009
            Thanks.
            Is the type of screw on the electrode also important? (steel, brass, ...)
              • 8747
              steel is the most often used metal although nickel is used also. stay away from brass as it forms an oxide when heated. the normal yellow brass turns black and is a poor conductor of electric.
