I have a whirlpool refridgerator , model number ET9FTTXLQ11, it is leaking water from the roof of the fridge. please help!
leaky fridge
I took a look at a technical drawing of that fridge and the highest thing in the unit that could leak would be the ice maker. If that were leaking though, the water would be apparent either in the freezer box or running down the back. There shouldn't be anything in the unit that can leak onto the roof of the unit.. Is the water on the roof outside the unit? Is it dripping from the cieling inside the freezer box? Where's it coming from?
If it's not the ice maker, my first suspicion would be condensation of some kind. Maybe the door seal is worn out? Damage to the fridges insulation could also be allowing warm and cold air to mix which would also cause condensation inside/outside the unit.
Sorry I couldn't be more helpful. Need some more info to pin this one down.Last edited by Psycho0124; 09-09-2009, 08:10 AM.If man makes it, man can fix it!
