GE Bottom Freezer clicks
  • Will B.
    • Apr 2009
    • 28
    I am having a problem with my 3 year old GE bottom freezer fridge. Today I noticed a clicking noise coming from the back of the fridge. It sounded like it was coming from where the board is. The compressor, at least I think that is what it is, is trying to start but it can't/won't. I unplugged it for a couple hrs to make sure that nothing else would be damaged. I plugged it back in and it still does the same.
    Can I leave it plugged in or am I better off leaving it unplugged?
    Thanks
    leave it unplugged. the compressor may be trying to start and the current relay is clicking. any food should keep for a few days if the lid isn't opened.
    • OTM Doc
      • Sep 2009
      • 11
      You need a new start/overload relay more than likely. It plugs onto the pins from the compressor. Take the relay unit off and shake it, if it rattles it is bad. They make a replacement, solid state relay. Parts houses carry it, $ 10-25.00
      • Will B.
        • Apr 2009
        • 28
        I pulled the relay off. Shook it and there is no rattle. I will replace it anyways. Is there something else that I should check? What about hooking the wires coming from the relay together and seeing if the compressor kicks on to test and make sure that the relay is my problem?
        • OTM Doc
          • Sep 2009
          • 11
          Inside the start/overload part is a start capacitor to assist the compressor. It will not work without the part. You can use a voltmeter to make sure you have A/C voltage up to the circuit. A wiring diagram should be with the frig.
          Go to REPAIRCLINIC.COM and type in your model#, then you can see the parts, etc.
          • Will B.
            • Apr 2009
            • 28
            Ok so I believe no what I pulled off is the capacitor. They have listed a PTC relay. Is this what I'm looking for? Is the relay under the black cover on the side of the compressor or is it on the electrical board? I can't get the black cover off on the side of the compressor to check.
            • OTM Doc
              • Sep 2009
              • 11
              If the relay and capacitor are separate, it could bet either item. Try shaking the PTC relay.
