Kitchenaid Door Microswitch Replacement
  • rjaggi
    • Feb 2010
    I have a Kitchenaid Model KUDS21MS1
    it has a problem where it will not run
    the door latch open determining microswitch must be maunally pushed to get
    the unit to turn on.
    I need a new switch - - where can I get one
    Is it easy to replace ?? it looks like two screws
    How does the switch determine the door is open
    as my old unit used a pin that went into a hole
    this unit has that hole covered with a metal plate that seems to go back over to the microswitch - could that plate be bent ??
    Kitchenaid [dishwasher] model KUDS21MS1. the door latch microswitch must be maunally pushed to get the unit to turn on. I need a new switch - - where can I get one
    You can get the door switch for that model at the following link:
    LINK > KitchenAid KUDS21MS1 Door Interlock Switch
    I don't know on your particular model. Door switches are not usually very difficult to replace.
    With the switch used on your model it looks like the lever on the switch activates the switch plunger and in turn, the switch's internal contacts.
