I have a GE W/M that is maybe 6-8 yrs old. On the spin cycle it makes a louder noise than before, sounds like a bearing or transmission noise. It is OK on the wash cycle. It also emits an odor of Diesel oil or gasoline at the end of the cycle. I have bought a new machine but want to give this one to my daughter; however, I want to fix it first. It still washes clothes just the same as before. I have replaced parts on washers and dryers in the past and don't fear taking this one apart but wanted to get some advice first. any idea what might be wrong? Transmission, bearing?All cycles work and motor is strong. No burned wiring smell. Pump works fine. However, if drain hose is laid on ground, all the water will drain from the tub. Is this normal? Any help is appreciated.
Washing machine making too much noise
Tags: None
Model number?
I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post it we can at least look it up to see what appliance design you're dealing with.GE W/M that is maybe 6-8 yrs old.
Forum Notice LINK > Please include Make and Model # in post
=D~~~~~~ -
Transmission bearing problem
That is one of GE's newer washer designs. On that design a howling sound during spin is usually caused by bad bearings in the transmission requiring the whole transmission to be replaced. Evidence of leaking onto the transmission is the most likely cause of the bearing failure. A new tub seal comes with the replacement transmission which will also need to be installed.GE [washer model] WLSE4210A0WW
You can see the transmission for that model and some general repair instructions at the following links:
LINK > GE WLSE4210A0WW Washer Transmission
LINK > New-Style GE Washer (plastic tub)
You would have to try to determine the actual origin of the odor. The belt, motor, clutch or transmission all might be possibilities.It also emits an odor of Diesel oil or gasoline at the end of the cycle.
=D~~~~~~Last edited by Dan O.; 06-23-2010, 08:50 PM.Comment
Thanks Dan O for your info.
Should I take the WM apart and ck the trany and find the source of the smell before I order parts. Is that what you would do? If the motor is the source of smell, junk the WM since cost of motor and trany is too high. If belt, rpl. If trany rpl trany. It will be nice if it is only the belt or trany and not the motor.Comment
Dan O; Have disassembled the GE W/M and found oil in the bottom of the cabinet and on the pulley of the trany. Motor and belt are fine w/belt showing a little wear. Had to cut off the tub nut with a chisel. Spin brake surface was oily and definitely not clean. Trany was leaking oil. Smell must be coming from trany oil. Need to order trany, tub nut and seal in bottom of tub. The spin brake surface was a separate piece like a gasket. Should I order this also. Trany had green barcode. Is there anything else I should look for to replace since I have the WM completely disassembled?Comment
Dan O; Parts will probably cost in the $200 area w/shipping. Should I even repair this WM or just buy my daughter a new one. Also, there appears to be water inside the plastic top that goes around the tub. I would think this would be hollow. Water could be forced in during the spin cycle. Doesn't appear to be any way to take plastic top apart. Thinking about drilling small holes to drain water then caulking them.Comment
Very possible.Trany was leaking oil. Smell must be coming from trany oil.
The seal comes with the replacement transmission. The nut is linked below.Need to order trany, tub nut and seal in bottom of tub.
LINK > GE WLSE4210A0WW Washer Hub Nut
AFAIK it should be part of the transmission assembly. It is not listed in the parts list so I don't even know if it can be ordered separately.The spin brake surface was a separate piece like a gasket. Should I order this also.
LINK > GE WLSE4210A0WW Washer Exploded Parts View
Not that I can think of.Is there anything else I should to replace since I have it completely disassembled?
Yes, to balance the tub during spin. That is how it was designed.there appears to be water inside the plastic top that goes around the tub. I would think this would be hollow. Water could be forced in during the spin cycle.
Don't even think about it!Thinking about drilling small holes to drain water then caulking them.
That will be up to you to decide.Should I even repair this WM or just buy my daughter a new one.
=D~~~~~~Comment
W/M repair
Dan O; Thanks for you great help and the two websites you posted for me. I ordered the transmission and installed it. W/M is running fine with no traces of the loud noise and odor.
Thanks again.
Glad to hear it. Thanks for the follow up.I ordered the transmission and installed it. W/M is running fine
=D~~~~~~Comment
Channel: Appliances
