Ok, I have gotten a bolt stuck in an annoying place and the head of it straight ripped off in my socket wrench (I put too much torque on it). Anyways, so I got a bolt stuck without a head to it. I resorted to drilling it out completely but I have run into problems.
I heard that cobalt drill bits work best, but that titanium works too. So I bought some titanium drill bits, and I am still struggling to make any progress drilling into the broken bolt.
I need some suggestions on what to do. Will a cobalt drill bit actually work (because titanium is not even making a dent in the bolt)? Or if that isn't working, should I go straight to using a dremel to grind in new marks in the bolt to exctract it with a screwdriver or something? I don't want to buy a welder and weld on a new nut to the broken bolt, so that's out of the question.
So, if titanium drill bits won't make a dent in my bolt, does that mean cobalt won't either? Should I just dremel it out? Thanks so much, I really need some help on this one. Take care
