Lately when we try to start our dryer, it will run for a short time then stop, displaying an E2 code. It's a Whirlpool Duet Electric, Model#GEW9200LW1. I did a search on the net and the common response was a bad thermistor. So I take the front panel off, and the duct assembly, to expose the thermistor. I took it out and tested the continuity of it. There was none. I checked the resistance of it, and I get around 10k ohms, which is normal for room temperature from what I've read. So, my question is this, according to the error code list:
E1 is an open circuit in the thermistor
E2 is a shorted circuit in the thermistor
My continuity test says it open, yet I get an E2 error? I'm half tempted to just go buy a new thermistor for 25 bucks, but if that's not the problem that's money down the drain. Any ideas what else it could be? I was thinking at first maybe the dryer displayed the wrong error code, who knows...
Thanks in advance!
Thanks in advance!
