kenmore upright freezer
  • LUCKYLARUE912
    • Aug 2010
    kenmore upright freezer keeps running, does not shut down at all model # 2539239785 please help
    thanks
    have you adjusted the thermostat?
      Keeping temperature?
      Is it getting too cold inside or is it too warm inside (which would likely be why it was running so much)?
      • LUCKYLARUE912
        • Aug 2010
        inside appears to be fine, food is staying frozen
          Freezer temperature
          If the freezer was working correctly, running all the time should produce extremely cold temperatures in the freezer (-10°F and below!). Have you put a thermometer in the freezer to see how cold it actually is? Are frozen foods unusually hard?
          If the freezer is NOT unusually cold after running continually, the appliance is not cooling properly and someone will need to investigate why. If the freezer IS unusually cold, there may be a problem with its thermostat (see the following link).
          LINK > Kenmore 253.9239785 Freezer Thermostat
